查看: 7|回复: 1
Automotive Nuts
管理员
Rank: 9Rank: 9Rank: 9
发表于 2024-2-2 14:33:05 | 显示全部楼层 |阅读模式
What are the nut welding machines available?
The main machines for nut welding include nut spot welding machines, laser welding machines, ultrasonic welding machines, etc. These machines are all automation equipment designed specifically for nut welding, with the characteristics of high efficiency, high precision, and high stability.
Nut spot welding machine is one of the most common nut welding equipment, suitable for welding various types of nuts. It adopts spot welding technology, applying pressure and current to the nut through electrodes to locally heat and melt it, thereby connecting it with the workpiece. Nut spot welding machines have the advantages of simple structure, convenient operation, and low maintenance costs, making them suitable for mass production and medium-sized welding needs.
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有帐号?立即注册
x
管理员
 楼主| 发表于 2024-2-2 14:38:14 | 显示全部楼层
GMT+8, 2025-12-17 03:50 , Processed in 0.115909 second(s), 19 queries .
