查看: 14|回复: 0
Bobcat 225G OCV?
发表于 2022-11-22 15:51:27 | 显示全部楼层 |阅读模式
Good afternoon, I recently got a Bobcat 225 G serial# KA818001. I put a new carb on and the got her fired up. No power at first until I found a bad connection at SR2. Now with her on max I’m getting 107 out of the auxiliary and 96 volts out of the weld lugs. The AC aux is a little low but the weld output voltage seems high. Can anyone give me any insight on how to test the OCVs and what they should be? Any help much appreciated.
GMT+8, 2025-12-17 03:59 , Processed in 0.102933 second(s), 18 queries .
