Where can I get SQUARE tread plate?
发表于 2022-11-22 15:51:26 | 显示全部楼层 |阅读模式
Where can I get "old school" treadplate that has squares instead of diamonds on it? You know, like they used in the 50s?Sent from my Lincoln Buzzbox using Tapatalk
Reply:Do you mean like this…
  or like this which most people call “checkerplate”…….?
Sent from my iPad using Tapatalk
Originally Posted by 52 Ford
First one! Sent from my Lincoln Buzzbox using Tapatalk
I can’t even remember ever seeing that pattern.
(Other than Google image)
Originally Posted by 12V71
One of my grandfathers had a big Dodge C800 with an Omaha Standard stock (cattle) bed that had that pattern, also had a matching 4 wheel pull trailer that had the same deck. These were from the late 60's. I used to get 10 bucks to shovel them out. What a ripoff
the squares made shoveling with a #2 square point a bit difficult.
Reply:Oh, the other place I recall seeing that pattern is in the rubber floor mats in an LMTV. Edit: maybe not. I know I've seen it in milsurp trucks, though.Sent from my Lincoln Buzzbox using Tapatalk
Reply:That is one big truck for a Ford from 1954, Funny how the Y-block was already out in big trucks but the pickups still had flatheads until '55. Had a '55 F100 with a 272, that truck probably has the 332.
I'll pay ya 10 bucks if you can cut some out and send it to me.
Reply:If you pay $21.5k for that one, you better start drilling for oil, not water...The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:This came up in an old thread.... "a wholesale supplier in Port of Catoosa just south of  Oklahoma Galvanizing "https://www.redpowermagazine.com/for...d-plate-steel/ss cp-14 is close, but if it's laid out diagnally on the steel, you'll waste a lot getting it to a straight configuration... https://www.checker-plate.org/checke...ker-plate.htmlThese guys in Tulsa seem to fit the first description... they might know what you are looking for.... Kloeckner MetalsLast edited by whtbaron; 8 Hours Ago at 07:29 PM.The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Originally Posted by old miner called Pop
I know Joe got some of that stuff a few years ago but its all gone, Im pretty sure he got it from a steel supplier near here Schuylkill County.Gonna do some lookin for you
Reply:Yea, but if it's special order it could be an expensive ticket...The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
I'm going to build some sort of drag/blade for my driveway that I can tow behind my truck or tractor Sent from my Lincoln Buzzbox using Tapatalk
no one will ever notice what your drag looks like if you pull it with this
Reply:In a perfect world, I'll end up with something sort of like this, but I want to add 12V motors to run all of the functions from a remote so I don't need a helper, but if I did have a helper, the hand wheels would still work. I bet it'd be a blast to operate one. When I grade the roads at the hunt club, that thing would be sweet. The reason I want to go for the old school aesthetics is cause making it look "pretty" is the only way I'm gonna be able to keep it in the driveway and I'm running out of room out back to hide my chit.
Reply:When need a pice the best wast the tractor 🚜 used parts aka scrape yard it can take hours to find just right one.Dave
GMT+8, 2025-12-17 03:59 , Processed in 0.076800 second(s), 18 queries .
