Lincoln Outback 185 no power issues
发表于 2022-11-22 15:51:25 | 显示全部楼层 |阅读模式
This is my first post so please bear with me. I have an Outback 185 that will not put out power. The technician changed out the circuit board and generator but still no juice. Any help is greatly appreciated.
Reply:The technician returned the welder to you not working ??????Did you request unit returned to you before complete repair done?Was this a Lincoln recognized repair center? A little more information required such as both A/C auxiliary and D/C weld both dead?
Reply:What is the unit Code# off the data tag.  There are at least 3 possible Code#s and there may be slight differences from one to the others.From your description, the "technician" simply manually flashed the rotor field to kick it off.  Shut it down and it won't re-excite by itself.  Sounds as if the problem is in the initial start exciter circuit/components.Last edited by duaneb55; 06-21-2017 at 12:45 PM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:I'm a welder repair technician, if the code on your machine is 11731 or 11825 there is a known issue, there is a relay in the machine that works in conjunction with the voltage regulator board, the relay fails to close providing the exciter voltage, there is a kit to repair this, it is part number S32031. To check if this is the issue move the leads on the top left of the relay (#6) down to #7, if the power comes up this is probably the issue.Don't leave the lead there or it will drain your batteryI'm having a similar issue with a machine I'm working on, the power works intermittently, haven't got it resolved yet but will repost if/when I resolve the issue.Last edited by Service.CWS; 02-13-2019 at 07:27 PM.
Reply:Good afternoon Petergun were u ever to fix your machine? Ive a couple of 185 that are doing the same thing. Intermittent power or quickly lose power after a few mins of running. Engine is fine just aux and power on welding side
Reply:How's it going service? I was just curious if you are still active on this board? If so, I have a question about a Lincoln Outback 185 code 11731 that you had answered a question about. The welder will not idle down when in auto mode and I followed your steps of taking the connector form #6 and moving it to #7 on the relay and can get it to idle down and the generator to work. We also have a brand new idle control board on the shelf that I installed to see if it made a difference, which it did not, same issues. I wanted to make sure if changing out the relay would fix the issue. Thanks in advance.
GMT+8, 2025-12-17 03:58 , Processed in 0.133816 second(s), 18 queries .
