查看: 13|回复: 0
Miler roughneck 2e- assembly number 038432
发表于 2022-11-22 15:51:24 | 显示全部楼层 |阅读模式
Miller roughneck 2e - assembly number 038432HelloThanks for allowing me to join.I’m trying to get my dads Miller roughneck 2e back in operation after sitting in the barn for many years.I have managed to get the Tecumseh engine running well and am now working on the generation part. It seems that the board assembly number 038432 is damaged and the Capsitor has fallen out of the board. The board does not look to be repairable.Can anyone offer some advice on a replacement?SN is HE750245
Reply:The board you refer to is the Static Exciter Panel which has been repaired/rebuilt by previous machine owners.  You can see the component break-down and values in the unit manual here:https://www.millerwelds.com/files/ow...s/O420_MIL.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Thanks Duaneb55I found a post from you awhile back about a company called weldtron that may sell a replacement.I can’t seem to make contact with them. Do you have any other source for a complete replacement board?
GMT+8, 2025-12-17 03:59 , Processed in 0.071197 second(s), 18 queries .
