查看: 14|回复: 0
miller spoolmate 100 inlet guide problem
发表于 2022-11-22 15:51:24 | 显示全部楼层 |阅读模式
Hello,so i was changing the spool on the spool gun and while i was feeding the wire through i accidentally hit the trigger causing the gun the arc out on the project i was working on it burned my hand pretty good but worse yet i think it has melted inside of the inlet guidenow it is a separate part in the manual however i am un sure if or how i can remove it to try and drill it out i have taken the gun apart and am able to get a 1/16th tig rod in there but i am un able to knock what ever is in there out enough to get the wire through, i have also tried torch tip cleaner but again they only go so far and then break/bend.any help would be greatly appreciated
GMT+8, 2025-12-18 12:14 , Processed in 0.165906 second(s), 18 queries .
