查看: 13|回复: 0
Sa250 armature loose
发表于 2022-11-22 15:51:22 | 显示全部楼层 |阅读模式
Hey yall! I recently acquired another sa250 I was able to bring back to life. Problem is she is shaking like the eddie money song. I narrowed it down to the armature shaft. The brush bracket has been rubbing against the rings(I doubt right terminology)the brushes sit on. I have an 89 sa250 and it's nice and tight and runs smooth. Whereas this one I'm able to pull the armature out a few millimeters. It definitely doesnt look like its snugged up compared to my other machine. How do I keep the armature shaft from spinning so i can snug up the big nut? There is a hole that looks like it's for a gear puller. I apologize in advance if my terminology is wrong. I would greatly appreciate any of yalls advice who have been through these machines. I'm tempted to replace the rings the brushes sit on because it looks like this has been going on for some time now and made a groove in the front brush ring. I would post pictures but im not quite sure how to.Thanks!Last edited by Weldingseabee; 10 Hours Ago at 05:34 PM.Reason: Update
Reply:Whether AC or DC auxiliary power, the rotor or armature respectively is retained to the main shaft with a large nut.  Remove the nut, lock tab washer and tapered collar and either component will slide off the main shaft.From your description it sounds like you may have a bad main shaft bearing.  The ability to move the rotor or armature in and out ~1/8" is likely just due to the flex plate that is part of the coupling to the engine flywheel.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Thanks Duane for your quick reply. I guess what I'm trying to ask is how do I remove the nut without the shaft spinning. Should I just hit it with an impact? I'm probably overthinking it.
Reply:I use my 1/2" air impact and appropriate socket to remove the nut after flattening the lock tab on the washer under it.  If you have to use a box, adjustable or pipe wrench instead of an impact, you can use a bar, very large screw driver or similar inserted thru the cooling slots of the generator housing to engage the cooling fan fins to hold the unit from turning.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Perfect! Thank you very much. I will update with my progress tomorrow.
GMT+8, 2025-12-17 04:10 , Processed in 0.073151 second(s), 18 queries .
