查看: 13|回复: 0
RR Track Anvil
发表于 2022-11-22 15:51:22 | 显示全部楼层 |阅读模式
Simple project right?  Hack up a piece of RR track into the shape of an anvil.  Well,  I got into it and the damn thing turned into an all day project.  Here's a pic of the humble start.  I'll post finish pics tomorrow when the paint is dry enough to flip over.  If you got a RR track anvil, feel free to post a pic or two.
My name's not Jim....
Reply:It's kinda cute. Can't wait to see the finished product.
Reply:I made this one for a young friend that helps me all the time. And yes it turned into a project.
I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:I've never formed the nose of mine into the typical anvil shape. I don't do any special forming with it. Drilled it and bolted it using conveyor belt washers.
"The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:I need one. Wonder if the RR would notice a piece of track missing......Just kidding I'll have to see if I can locate some.Offering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.
Reply:Here's a pretty neat anvil forged from a rail.  The little hammer is forged from 52100 steel.
"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:After you guys made your anvils, did any of you do any heat treating to the anvil?
Reply:Here's one I built for a friend. It was a lot of work. I left half of it rounded and built it up for half of it square edged. You want to use a rod with moly in it as it will hold up to the hammer blows better. I use 110-18 when I reservice old anvils that are bellied in or have bad edges. It's a common rod for impact resistance welds. You might want to reverence this http://weldingweb.com/vbb/showthread.php?t=34618I can't get the picture to load. I've posted it before, you may be able to find it. Sorry.
Reply:Thanks anickode I was going to ask where do you find a 2 foot section of track.Dave ReberWadsworth Ohio
Reply:I think I went too far this time.  It's so pretty I don't want to use it.  It spent more than just a few hours in the mill getting the working surface flat and square.  Then flipped over and fly cut the base.  If you compare the pics you'll notice I did add some material back onto the base.  It just didn't look right.  The horn was carefully laid out and ground by hand to be symmetrical.  Every working surface was sanded down with 300 grit.   I stopped short of breaking out the buffer and going for a mirror finish.  If it ends up on a book shelf, I might do that yet.Dimensions....12" from tip to tail, 4 3/4" tall, flat surface is 7" by 2 1/2".
Reply:Yo man, awsome job
that may be shelf worthy. The one I showed was done with a grinder, file and emory paper
Reply:Wow boostin!!! Awesome work!! How bad was the track to mill? I'm surprised it hasn't hardened to all get out.
Reply:The sides of the rail actually machined pretty easy with a chinese HSS end mill.  Produced dust kind of like cast iron.  The weld I put on top needed to be fly cut with carbide. No more than .010" per pass.  The underside of the base was hard as hell.  I didn't cut it so much as polish it with my quickly dulled carbide.  It was already flat and parallel to the top so I let it go.Last edited by Boostinjdm; 09-09-2012 at 03:15 PM.My name's not Jim....
Reply:Thats to nice to use
you may want to make one like this one I made to work with
www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Very nice job there. I'm impressed. I wondered how well they would machine when I saw the one Oldendum posted up. I could use a little anvil like that, especially the horn. My 50 lb Fisher isn't too abd, but the horn leaves a lot to be desired.  I was eying up some old rails laying 1/2 buried in the ballast at the side of the road bed the other day,  while looking for some spikes to forge. I think someone would say something and probably call the cops if I showed up with the 14" demo saw and the abrasive blade and tried to cut up a few chunks however. I was thinking the rail would make great dies for a power hammer... This is one of those times I wished I had a small portable OA rig. Come to think of it I've got 2 40's of acet, and a 40 of O2. Probably just need the reg adapter to make the acet reg fit the 40 and some way to haul the cylinders and I could probably torch cut what I need. Still everything is right out in the open next to the houses near the station, so somebody would probably still call the cops. I need to keep looking... Sad thing is about two months ago they ripped up some rails leading to the old freight station in town when they were turning it into a bar and needed the space for a deck and handicapped ramp. If I'd thought of it then, I could have probably gotten all I wanted if I'd given them scrap value for one of the rails....No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Just outside hanging some laundry, and thought it would be appropriate to share one of my shirts. LOL
Reply:That turned out great. Impressive work for sure.Sent from my busted Desire using Tapatalk.
Reply:When I say that little anvil was forged, I mean forged.  Then stress-relieved twice and annealed.  And it was heat-treated.  Old fellers do that stuff.
Reply:Here's a dolly and a small anvil I made... The track I used is supposedly part of the original track installed in Atlanta during the civil war...Polished with an old style "locked" DA sander with 400...(locked means it spins more like a grinder)
Last edited by DemonSpeeder; 09-09-2012 at 06:39 PM.Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:nice, needs a hardy hole..
Reply:Absolutely gorgeous.  You have boosted plain track into something that would be allowed in the house.How about making a small all metal hammer to go with it a crack nuts on it as it sits on a coffee table.A girl could drape her necklaces over the horn and set her rings on the top.Or use as an anvil and be happy it is so nice.Miller Syncrowave 180SDLincoln WeldPak 100 with gasHandheld Milwaukee BandsawO/A Cutting Torch
Reply:Wow!Boostinjdm and Oldendum those are frikkin' beautiful. I've got one that stays on my welding truck, but after seeing y'alls there's no point in posting pics of mine.
Brian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:Holy HeII !!! That is freakin NICE!!!
Originally Posted by Reebs
Thanks anickode I was going to ask where do you find a 2 foot section of track.DemonSpeederThis was bolted to a welding table I had back in 1976. I need to bend some rod iron so I took the torch and cut the notch to keep the bar from slipping off
After seeing some of the others on here I will have to clean this one up and mill the top flat
Reply:Very nice job Boost! That's a great idea!Tagged"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!
" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:That anvil is beautiful.I've wanted to make one for a long time.I did once make the ol' R.R. spike slag chipping hammer.But spikes are soft and point gets mushroomed over quickly from use.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:No need to go cutting up on rail sticking out of the ballast... AND don't get caught trying! The charges these days are terroristic in nature, Homeland Security and all. Even if we all know the line has been abandonded for years, some goody twoshoes will be on their cell while driving to turn you in. The easiest way to get a chunk of rail is to catch one of the section crews working and tell them what you're looking for. They've probably got exactly what you want on the truck, and if not can tell you where to find it. At least that way you asked if someone does say something. Speaking as a humble Railroader...Oh and BTW, Nice project! I have a couple of chunks that just found a new use..."The beauty of the Second Amendment is that it will not be needed until they try to take it." - Thomas Jefferson If the Lights are a Flashin', STAY OFF the tracks!!! It might be me at the Throttle...
Reply:This is mine. It's not fancy but it puts about 100lbs directly under my hammer. Also being bolted to the 4x6 and set a foot and a half in the ground it doesn't ring. No ringing keeps the neighbors a little happier.
Reply:Awesome DUDE !!!!!!!!!!!!!  That's for going with you to church on SUNDAY. Man, I can't getmy shoes that shinny . You be "THE MAN". I would just keep that one in the kitchen. Amazing !
Reply:Near my folks place there are long sections of old track laying next to the new. I might take a walk for a 1' section. I hope I don't get the cops on my buttDave ReberWadsworth Ohio
Reply:uh wow... nice job. that thing is purdyESAB Heliarc 252
Originally Posted by DSW
Did you harden it? Apparently some spikes are made of high carbon steel and so can be hardened.http://www.bladeforums.com/forums/sh...ailroad-Spikes
Reply:After seeing some of these anvils
mine didn't look so good soooooo
Reply:Sweet...What did you polish it with??Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:all you guys are making me feel guilty. I have tons of rail sections all day long. I wish I could give everyone a piece. Then again, my job is on the rail road right of way. I am expected to be there. I agree, do NOT get busted taking stuff off the right of way. The FBI has been teaching a "See something, say something" mantra to us.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:So I had a piece of RR Iron sitting in the corner for years and got bored the other day, below is the result!
Cheers Andrew
Originally Posted by Hemi-T
That is my problem too.  Where do you get old RR track?  I've never seen any or sale.  Please enlighten me.
Reply:wow, lots of great looking anvils in this thread!
Reply:RR iron is easy to get around here, just drop down to South Australia and I'll point you in the direction of some
Cheers Andrew
Originally Posted by nonhog
In my case (Tacoma Wa.) there is a place that sales RR ties. They also sell track sections $5 for 6" $20 for 2' . Check for places that sale RR ties? Worth a shot.
Reply:Pretty sure this is the place. (Puyallup on River Rd.) .... http://www.akrailroad.com/tacoma-yardMiddle age newby
Reply:Some works of art right there.  I can't even imagine how much time you have invested in that one.---No good deed goes unpunished---
GMT+8, 2025-12-17 04:12 , Processed in 0.098227 second(s), 18 queries .
