Another shop stool idea. intentionally making it more challenging
发表于 2022-11-22 15:51:22 | 显示全部楼层 |阅读模式
I`ve been making many of stool, but to fill these dark and lonely evenings somehow, thought about making another one. Not so much for sitting, but to use for grinding, cutting and painting small stuff on.To make it a little bit more challenging, it will double as a stand(telescoping pipes) for a support(to support the ends of long pipes off the table) and have some diagonal bar design thats absolutely unnecessary. But will require the famous "measure at least 10 times and cut once".Any ideas appreciated, on how to make a fancy stool.
Reply:I appreciate your thinking regarding multi purpose devices but when I sit I prefer to be reasonably comfortable..
Telescoping material support…
edit. both the stool and chair in photos were rescued from the dumpster the ss stool came from a pharmacy relocating and the chair from a travel agency that was an early victim of Covid 19 Sent from my iPad using Tapatalk
GMT+8, 2025-12-17 04:12 , Processed in 0.065146 second(s), 18 queries .
