查看: 13|回复: 0
Thermal Arc 186
发表于 2022-11-22 15:51:20 | 显示全部楼层 |阅读模式
Hey guys,....I have a Thermal Arc 186 w/ Foot Control,....that I've had for several years.  Shortly after I purchased this machine (new), I upgraded the Torch to a 17 series from USA Weld  https://usaweld.com/collections/ther...27920171466835As of late,.....I'm in situations where the Foot Control is not practical (Roll-Cage tubing work) and I really need something with a Fingertip control.What are my best options ?Any help or direction would be greatly appreciated.
Reply:You'll need an 8 pin plug torch. Available plug and play from ESAB and Weldcote. If you need one longer than 12' you'll need to buy a longer power cable and easily install it or look to CK for other higher cost options. Easily done.Thermal Arc 320SP ( Lorch )Cobra PythonsThermal Arc 300 AC/DC  ( Sanrex )ESAB 301i AC/DC  ( Lorch )Thermal Arc 161STL  ( WTL )Thermal Arc 190S  ( Sanrex )Cut Master 82, 42. Cut45 ( WTL )Victor Gas Apps.Boxes and boxes of welding crap.
GMT+8, 2025-12-17 07:10 , Processed in 0.096487 second(s), 18 queries .
