查看: 14|回复: 0
Lincoln Ranger 305g battery
发表于 2022-11-22 15:51:20 | 显示全部楼层 |阅读模式
Hey so i recently bought a ranger 305g. It did not come with a battery. On the lincoln specs it says it requires a 12v group 58 435 current cranking amp battery. I searched that up and cant find one locally. A store near me has a 12v group 58 with 500 current cranking amps will that work fine? Thanks for any help
Reply:More cold cranking amps is a goog thing.  The main thing is the size/shape of the battery to fit the space it fits in, and of course being 12v.Miller Multimatic 215Spoolmatic 150 spool gun, Miller TIG kitPrimeweld Cut 60 Plasma CutterVevor Pipe StandsBauer Portaband/Swag tableGrinders-Milwaukee, Porter Cable, DewaltArcUnion M-20 portable rod oven
Reply:Not sure if a Costco is available where you are, but I just bought a group 58 Interstate batt for $75 w/550cca. Fired my 250 gxt effortlessly.
GMT+8, 2025-12-17 04:13 , Processed in 0.100500 second(s), 18 queries .
