30XP switching between FineCut & Standard... keep electrode for each?
发表于 2022-11-22 15:51:19 | 显示全部楼层 |阅读模式
I recently acquired a 30XP.  I made some guides for parts I need based on the finecut consumables, but I have some aluminum junk to scrap and want to use the standard nozzle to cut it up.  Am I best off using a separate electrode for the standard nozzle so when I need to change the finecut nozzle I will change out its electrode too?  Or is this just too fussy?  I know I also need to use the shield with the standard nozzle rather than the deflector.
Reply:Too fussy.Same electrode for bothSent from my SM-G996U using TapatalkMillermatic 252 MIGMiller Dynasty 200DX TIGMiller Spectrum 625 PlasmaAltas 12x36 Metal LatheBridgeport Milling Machinewww.psacustomcreations.com
GMT+8, 2025-12-17 07:10 , Processed in 0.097640 second(s), 18 queries .
