Dinse 25 gaz-thru to dinse 40
发表于 2022-11-22 15:51:18 | 显示全部楼层 |阅读模式
Hi!Been finding a not much used miller tig kit. The guy says it's a dinse-40 connection with a gaz tube to connect. My welder is a multi 215 with a dinse-25 gaz-thru.Is there an adapter existing to fit the kit?I will need a pedal, regulator and pure argon but i think the price is good (225$ CAN with consumables)
Originally Posted by shovelon
No peripherals? How do you even know it works?
GMT+8, 2025-12-17 04:10 , Processed in 0.072875 second(s), 18 queries .
