查看: 14|回复: 0
Linclon weldan Power G8000
发表于 2022-11-22 15:51:13 | 显示全部楼层 |阅读模式
I have a G8000 it welded fine last yr this yr it has a problem with not going to high idle wont do it from witch or when trying to weld put on new carb and ignition coil I am at a loss I have 12v for idle solenoid when toggle is at low and no when switched to rabbit  but still wont go to high idle .
Reply:So with no 12VDC+ power to the idler solenoid (wire #213) the solenoid does not extend to allow engine to go to weld/power high idle speed?Do you have the carburetor linkage installed correctly?Onan, B&S or Kohler?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
GMT+8, 2025-12-16 21:57 , Processed in 0.098009 second(s), 18 queries .
