Lincoln 300D won’t rev up when using grinder
发表于 2022-11-22 15:51:12 | 显示全部楼层 |阅读模式
My classic 300D won’t rev up when using a grinder. The grinder will start but won’t go to full RPM unless you flip the switch to high idle . It will rev up when you strike an arc ? Guessing idle board ? Anybody got any ideas been sitting awhile.
GMT+8, 2025-12-17 04:12 , Processed in 0.109811 second(s), 18 queries .
