Lincoln arc welder & ignoramus
发表于 2022-11-22 15:51:12 | 显示全部楼层 |阅读模式
Hello.  I am totally ignorant about welding.  There is a Lincoln AC 225 arc welder for sale for a nundred dollars.  Can a no-nothing like myself learn to weld with such a machhine?
Reply:Yes.  Depending on what you desire, this machine could be you goto never need anything else or you could quickly out grow it and move on to another process. Given that it is AC, you will probably many something different at some point.  It is a good machine to start learning to “stick”metal together.
GMT+8, 2025-12-18 08:57 , Processed in 0.064919 second(s), 18 queries .
