Miller Spoolmatic 30A $200
发表于 2022-11-22 15:51:11 | 显示全部楼层 |阅读模式
Hi all,This is a project I'm not going to get to because I got the push/pull setup for my 350P.  This is a Miller Spoolmatic 30A that needs some work.  The drive motor is fine, it feeds wire and the speed dial works as it should.  At some point the power lead where it goes into the housing got messed up and it appears they tried to solder it in place.  I think the solder could be removed, and a new threaded end put on the power lead, but I'm not going to get to it any time soon.  The control wires near the connector have a couple of bare/rough spots...I was going to shorten the wires since it's so close to the plug.  $200 plus actual shipping from zip code 48111.  I've got it in a box that's 19x19x7 and weighs 20lbs if you want to calculate what it would cost.I'm flexible on payment methods...have PayPal, Zelle, cash, MO, check that has to clear, etc.
Check out my bench vise website:  http://mivise.comMiller Syncrowave 250DXMillermatic 350P with XR AlumaProMiller Regency 200 with 22A feeder and Spoolmatic 3Hobart Champion EliteEverlast PowerTig 210EXT
GMT+8, 2025-12-18 08:57 , Processed in 0.062604 second(s), 18 queries .
