查看: 15|回复: 0
Dodge Ram Frame Repair, Need Advice
发表于 2022-11-22 15:51:09 | 显示全部楼层 |阅读模式
hello all, this is my first post so hope i formatted this correctly. i currently own a 2009 Dodge ram 1500(purchased in beginning of 2022). It is a michigan truck so needless to say i’m sure it’s seen it’s fair share of winters and it is definitely evident. the frame has already started to rust fairly bad towards rear around torque arm mounts on both sides of truck. I was wondering the most efficient way of repairing this. Is butt welding patch/fish plate over repair area a good idea for this, or is it better to shove plate inside frame and weld from frame to new plate, and fishplate over that section?  I have also considered using square tube to shove inside of frame and welding to that. i’ve seen many videos of people cutting out rust section and just welding a plate over section to existing good metal on frame but i’m not sure how good of a repair that really is. i do have a decent amount of mig welding/fabricating experience so i am not worried about getting good welds, mostly about the proper way to reinforce this area, any advice is greatly appreciated!
Reply:that thing looks to be in rough shape. how rusted is the rest of the frame ? sometimes its better to cut your losses and buy something else.invertig 221 water cooledhypertherm powermax 30xpfronius transpocket 180fronius transsteel 2200fronius iwave 230i water cooled
GMT+8, 2025-12-18 10:43 , Processed in 0.057471 second(s), 18 queries .
