magnum 100l wiring
发表于 2022-11-22 15:51:08 | 显示全部楼层 |阅读模式
I have a lincoln magnum 100l that the wires have been clipped. They are white with some indiscernible writing, but look identical. I bought a new plug end. Does it matter which wire goes to which pin? Would it hurt to "test" and just connect them one way and if it didn't work, switch them? Just to see if it would feed. Would it hurt anything if connected incorrectly?
Reply:Does not matter. (two contactor wires)Esab/Lorch ET-220iEsab 160i caddyEsab CV353Esab 875Thermal LM-200/ Lincoln feedersThermal 60i- 3phaseThermal Pro Power Engine DrivePak 50Thermal 15cINE 1500Lincoln 250 stick
Reply:awesome...THANKS!
Reply:How many pins in connector ? Do you know which two are contactor ?
Reply:2 pins only
GMT+8, 2025-12-18 17:35 , Processed in 0.103620 second(s), 18 queries .
