Miller Bluestar 2E AC/DC help!
发表于 2022-11-22 15:51:07 | 显示全部楼层 |阅读模式
Picked up my first generator unit yesterday as I need something for projects and some pipe fence building. The Craigslist selection wasn't great but I found this Bluestar and even though it wasn't welding as is I picked it up knowing that it was a little bit of a risk. It did run but only with the choke on. The guy told me it needed brushes to he replaced them but hadn't put them on because of the carb issue. Just for kicks I put the brushes back on. I could not find a diagram so I places one wire on each brush.
I am assuming the prong the wire is placed on is irrelevant?? I got enough power to make some sparks but it would not establish as arc.I also noticed the wires to the throttle solenoid were cut. The solenoid tested okay with 12v put to it but I need to get the engine running right to even test the output on the wires that are supposed to control the solenoid. I assume the first step is to rebuild the carb.Any advice is appreciated.  SN: JG068586
Reply:Based on the SN you posted, here's the manual http://www.millerwelds.com/om/o424b_mil.pdf for your machine with the wiring diagram on page 20.With the unit off and ignition switch in the run position you should have battery voltage between the two brushes.  If not, check for a failed open flashing diode D8 that is located in the harness between the engine and generator (wires #1 and #4 if I'm not mistaken).They're not too bad but you could also clean up the slip rings with some 320grit sandpaper.If you have battery voltage at the brushes, start the unit and see if this voltage increases to something above 170VDC.  If DC voltage at the brushes doesn't increase above battery voltage with the unit running, check for a bad WELD/POWER switch or open(s) in the field voltage bridge rectifier SR1.You can use the manual wiring diagram and parts break-down to help identify these components if/as needed.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:I have the DC only bluestar 2e. It is a very nice welder. Welds great. Only complaint I have is the tecumpseh 16hp motor is a bit loud. The motor is the tecumpseh OH 160 model. Carb is a Walbro LMH. You can buy a rebuild kit for the carb on eBay. Your motor is not getting enough fuel if you have to run it with the choke on. Carb will require a thorough cleaning first, then check and verify your float height is correct. Then try running it again.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Thanks for the help. I ordered the carb kit yesterday. I also found that the throttle solenoid is getting power.with the engine off I am getting battery voltage at the brushes but when running it does not seem to jump to 170v. Ill look into it some more today.
Reply:You may not necessarily need the rebuild kit for your carb but for the price of it, it doesn't hurt. When I got my bluestar 2e welder, the carb was over flowing a bit of gas. It ran ok but the motor would backfire when it idled down when welding. My issue was my float height in the carb. With the carb bowl off and the carb upside down, the float should be sitting parallel with the carb body base. If it's not, bend the small tab that controls the inlet needle. Adjust that tab till the float is sitting parallel with the carb body base. Once my float height was set correctly, the overflowing of fuel stopped and the motor idled down smoothly with no backfiring. Once I had those issues resolved, I replaced the spark plug, air filter, installed a fuel filter and changed the oil.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Okay I've got it torn apart right now. Ill be sure to get it set right. I have another question, this time about the battery. My welder did not come with one. I have been using the lawn mower batter (275 cold cranking amps) to start it and it doesn't do a great job. How many CCA would you recommend I look for when I buy one?
Reply:It states in the manual what they suggest you use for a battery. I've honestly been using a marine battery from my boat on mine. It's much larger than a lawn mower battery. It does a good job of cranking over the 16hp tecumpseh. There are much better batteries out there today than they had back in the 80's.Last edited by snoeproe; 07-11-2015 at 08:22 PM.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Thanks for all the help. Cleaned up the carb and picked up a battery today (360 CCA) and I think it do just fine. I temporarily mounted the machine to my homemade trailer I threw together mostly out of stuff I picked up for free. Since the welder didn't come with a battery box I mounted the battery in the toolbox and used the quick connect plug that came on the battery cables. Hopefully the pics are right side up this time.
Reply:Just had a look at my battery. 650 marine cranking amps. Rolls her over with no hesitation at all.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I reinstalled the carb after cleaning it (still don't have the rebuild kit). It runs only slightly better, still needs at least half choke. While it is running though I am still getting very low voltage at all three 115v plugs and only small sparks from the welding leads. The d8 diode snapped in half when I was disconnecting the clips on either end so I will be replacing that but I'm not sure that is my problem. My weld/power switch is controlling the solenoid but could it still be the problem? If so how do I test it? I also am unsure of what you (Duane) meant by checking for opens on the SR1 rectifier. I apologize for my lack of electrical troubleshooting skills.
Reply:What did you clean the carb with?  If you didn't use a chemical soak type carburetor cleaner you likely still have blocked fuel/air passages in the carburetor body sections.Diode D8 is known as the flashing diode which provides battery voltage to the (+) brush for initial rotor excitation to start the generating output process.  As you originally had 12VDC at the brushes, it was functioning as it should and you'll have to replace it in order to continue troubleshooting.The WELD/POWER switch is a 4-pole switch and is performing three different duties only one of which is controlling battery voltage to the throttle solenoid.  Another is disconnecting the auxiliary power outlets from the generator output to prevent highly excessive voltage from being connected to any device plugged into the unit in WELD mode.  The third is connecting the correct exciter output windings in WELD and POWER modes to the field circuit bridge rectifier SR1 to provide the correct field voltage in the selected mode.It is the third function you need to check the switch operation for.  To do so, you should have continuity between the center terminal wire #2 and side terminal #12 in WELD and #2 and #13 in power.Here are a couple links to testing a bridge rectifier.  The wincogen.com is a written procedure using a multimeter that doesn't have a diode test function and the youtube link is using a meter with a diode test function.  Although the youtube sample bridge rectifier is of a different configuration than that of the one in your welder, their function and test procedure is the same.http://www.wincogen.com/files/downlo...er_testing.pdfAs for your question regarding which wire goes where at the brushes, if you have them backwards your weld output polarity will be opposite what your selector switch indicates.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Thanks a ton for the great help. I'm fairly certain the rectifier is shorting because I am getting reading when contacting between the + and AC on even when I reverse the leads on the multimeter. The corrosion on the terminals makes getting quality ready a little difficult. Im also having a tough time finding a new rectifier (and switch) online.  http://weldmart.com/MILLER%20POWER%2...PAGE%20MST.htm Is "D" the part I need?
Reply:When you cleaned the carb did you remove the inlet needle and blow air through all passages?JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I soaked the carb today and blew air through all of the passages. The fuel hose barb had some bad build up inside that I rimed with some naval jelly. After reassembling it will run on WELD with no choke but still needs about 1/3 choke in POWER.
Reply:Sounds like the low speed/idle circuit might still have an issue.  What did you soak it in?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:I just soaked in diesel and blew it out with aerosol carb cleaner and compressed air. You think some chem-dip would do much better job? Even though it runs at higher rpm I can still tell that there is an issue.
Reply:The one problem I had while cleaning the carb was the main jet. I tried to remove it but it seemed like I was going to do more damage than good so I left it in and cleaned it the best I could. I just now saw a YT video with someone saying that the main jet on that carb is never supposed to be removed or adjusted as it could case issues.
Reply:Sounds like it's getting better. How does the spark plug look?JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:The plug looks good. Wasn't bad when I got it but cleaned it anyway and it's been fine.
Reply:I guess I will get some chem dip and try to find a rectifier tomorrow. I replaced the D8 diode I broke btw and I'm back to about 18v at the aux. power plugs.
Reply:I usually use brake/contact clean spray for cleaning carbs. Is your fuel tank full of old gas? Some fresh gas with a little sea foam in it will help the carb some what once you get it running correctly. Does yours have a fuel filter on it?JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Drained all of the old gas when I got it and yes it does have a fuel filter. The fuel hose seems a little bit questionable to me though. It's transparent blue. I might just pick some better stuff up if I go in to town today.
Reply:I am getting between 10 and about 22 volts. It stays around 20 while on WELD but still fluctuates with the engine.
Reply:I am getting about 15v DC from the + and - on the rectifier.
Reply:New rectifier or old one?  If the old one, again, need to get a good bridge rectifier in the circuit or it won't produce proper output.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:That's with the old one. Is the 20v at the exciter votage output leads close to normal? Just wondering if something is wrong before power even gets to the rectifier.
Reply:Good to know. I'm pretty sure it and the filter are new. The electronics supply said they could have a rectifier in on Friday. Hopefully they have what I need.
Reply:Now I'm getting a little frustrated. Got a multimeter with a diode function on it now so I actually removed the rectifier and it checked out fine.
Reply:PM me an email address.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Old thread, I know, but I thought I would make a final post in case it would help someone in the future. After much more electronic fiddling I found my bonehead mistake that had been causing me so much trouble. I hate to admit it but when I replaced the D8 diode I managed to put in in backwards. Whoops. As soon as I swapped it around and truck an arc it idled right up like it should. It welded then but there was still a fuel issue. I replaced the fuel line with some 5/16 and replaced the in line fuel filter as well as rebuilt the carb with the right[I] kit this time. I also did some more carb and governor adjusting. Now I have a fully functional welding machine!
Reply:Good job and thanks for posting the update.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:?I had the same problem with  high speed jet/ numerous soaks and blowing would not remove varnish. Finally a welders tip cleaner did the job and now idles and rev high speed with out choke .Duane tried to tell me it sounded like stoppage but ?I could not believe varnish is so hard to remove Don
Reply:Varnish is so awesome, we use it to protect wood from marine exposure!  ;-)The chem-dip can is one of my best friends.  The benchtop bead-blaster is right with it, able to clean hardened gak out of float bowls and from around throttle shafts and blades easily and safely, but gotta exercise care, as it can stuff beads into a sensitive orfice really easily too.On cast-iron carb bodies, I've been known to dunk 'em in phosphoric-acid based cleaners for a few minutes, then rinse, dry, and chem-dip them again... when a carbeurator casting looks NEW, and the passages are all clean, it's a good START to a good carb rebuild.
Reply:Not sure if anybody uses this website still, But i just recently purchased a Miller Bluestar 2E AC/DC. It has been sitting for a couple of years and the carb was Gunked up majorly. As I pulled the carb apart to clean it, The jet in the bowl was clogged and went to pull it out to clean it throughly, And just my luck it broke in half as I went to break it loose. Would anybody by chance have a Walbro LMH carb they would sell? Thanks in advance.
GMT+8, 2025-12-17 11:05 , Processed in 0.196464 second(s), 18 queries .
