straightening 2" hollow square section steel
发表于 2022-11-22 15:51:06 | 显示全部楼层 |阅读模式
I was gifted some 2" square hollow section steel lengths about 8ft long.they all are bent in the center, like a .5-1.5" belly from ends in one plane only.Any idea how to straighten them ? not looking for perfectly straight.I tried using a hydraulic jack and welding some brackets to hold a pair belly to belly on the ends and jack in the middle(belly) but they simply sprung backthey were used in shipping containers carrying liquids in a giant bag which fills the container, they are placed across the door end so the bag sloshing bends them.thanksMM 180
Reply:Repeat your sandwich method with heat
Reply:How straight do you really want or need them to become? In other words,  does a slight bend really matter?Sent from my SM-G996U using TapatalkMillermatic 252 MIGMiller Dynasty 200DX TIGMiller Spectrum 625 PlasmaAltas 12x36 Metal LatheBridgeport Milling Machinewww.psacustomcreations.com
Originally Posted by lennyk
I tried using a hydraulic jack and welding some brackets to hold a pair belly to belly on the ends and jack in the middle(belly) but they simply sprung backthanks
Originally Posted by Lis2323
when bending with the jack you will need to bend "BEYOND" straight to allow for spring back.
Reply:Rosebud.Heat the long side. It'll take a few round of cherry red. All metal shrinks when it cools.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:I loves heat shrinking.........................makes me all warm and fuzzy.  Learn to heat shrink, and distortion will never rule your life again as long as you live.
GMT+8, 2025-12-18 13:53 , Processed in 0.092748 second(s), 18 queries .
