SA200 - getting "sparkles" in the wrong place - simple fix or major expense?
发表于 2022-10-9 15:51:54 | 显示全部楼层 |阅读模式
Have searched this forum with no luck.  SA 200 1964 Code#5337.  "Field find".... Have it up and running - no problems there. (Will have to go through the R57).  Have auxiliary power - runs grinder fine. Have not checked receptacle voltage yet. But here's the problem -  will barely "sparkle" at the electrode and looking at the main generator (viewed from the exciter end, of course), at the 6 o'clock position, just inside the main generator housing, there is a lot of sparking/arcing going on.  Have cleaned both commutators with the proper brush seating compound stone and they are not arcing.  Before cranking it up, I heeded the advice to clean out the rat's nest/debris, etc. and all I had was a lot of oak leaves, in the main housing, which of course I cleaned it out.  I'm betting that the SA200 gurus on here, already know what is causing this "light show".  So, is this a simple fix or do I need to do a complete teardown and spend an obscene amount of money on various electrical components?  If it's major, I will put it back under the shed and do it this winter.  If it is (which I doubt - knowing my luck) a simple fix, I would like to go ahead and repair, just to verify that it will indeed produce proper welding current.  Thanks in advance for your help and time.
GMT+8, 2025-12-18 10:26 , Processed in 0.095464 second(s), 18 queries .
