Question for Duane
发表于 2022-10-9 15:51:54 | 显示全部楼层 |阅读模式
file:///var/mobile/Library/SMS/Attachments/fc/12/C2E939C4-C02B-4FBF-B1DD-C6045A8F8863/68659890127__B430C981-2CC0-490B-9457-DC852065FBB9.heicCan I spin a shield arc 250 with a sa200 to start it ?
Reply:Yes, think you can and have done it but many moons ago and should have duane splain it.  I  dont remember the gears and the settings.Last edited by Sberry; 2 Days Ago at 09:17 AM.www.urkafarms.com
Reply:I know how to set them and how to hook them up just don’t know if a sa200 will spin a sae 250
Also does the code and serial number chart pertain to welders other then sa200
[attach=config]1744263[/attach
Reply:I believe it will, I rolled a 300 with a 200, little difference in engine compression with 250www.urkafarms.com
GMT+8, 2025-12-18 13:53 , Processed in 0.058006 second(s), 18 queries .
