building a new utility trailer from boat trailer
发表于 2022-10-9 15:51:50 | 显示全部楼层 |阅读模式
Ok so my question is should I weld the new 4"×2"rectangle bar I'm using to widen my trailer. Or thru bolt it? I really like the options thru bolting opens up for me but it really is about the strength and safest way. I'll add some pics after my phone charges so you can get a better understanding of what I'm trying to accomplish here. Thanks in advance for any advice.
Reply:You failed to mention what your welding proficiency is. If you've never welded and want to welder up with your new Harbor Freight 125 amp flux core welder then lose that thought, nobody wants to be on the road with that trailer, once you weld that trailer you have assumed all liability for it and anything that may or may not happen as a result of an improper weld, especially one done with a wire welder in the hands of an inexperienced welder.NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINELET'S GO BRANDON!"Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
Reply:Sorry my phone was showing on me lol. I weld this trailer had holes in the whole frame already so that's why I'm wondering if I ran the 3' 4x"2" rectangle through the channel but thru bolted it wouldn't it still be stronger and rigid? Or thru bolt and a couple good tackle welds? Hell I don't no lolhttps://photos.app.goo.gl/zugmgSjnVNrUxfsA7
Reply:Here is the link to the pics the OP was trying to lost. He ran two words together so the link didn't work.https://photos.app.goo.gl/zugmgSjnVNrUxfsA7I am not sure what kind of potato you used for that photo, but try to post new, clear pics in the daylight. Pics of the trailer overall, location you want to put the beam, etc.In addition to the questions above, what is the trailer going to be used for? Weight carried, etc? If you modify the frame to carry more, are you adjusting everything else to accommodate the additional weight?Millermatic 252 MIGMiller Dynasty 200DX TIGMiller Spectrum 625 PlasmaAltas 12x36 Metal LatheBridgeport Milling Machinewww.psacustomcreations.com
Reply:As mentioned, any welding on a trailer should be done by someone that knows what they are doing. Converting a boat trailer to a utility trailer is not a good idea, unless you know what you are doing. Making it wider doesn't mean that the side rails are strong enough for what you are doing. Axle placement and tongue weight can be another issue.  Not knowing what your limitations are, from what you are saying, go buy what you need. If you are planning on using this off road around your property, that's fine. Pulling it on streets and in traffic, No !If you decide to do it the way you want, make sure you have insurance. Does title say, boat trailer ? How do you plan on getting a license plate for it ? Material cost are crazy almost all over and if you price it out, you can probably buy for less and you have an ''engineered'' trailer designed for a dedicated load. Tongue length, axle placement, and materials used are designed for a specific load.
GMT+8, 2025-12-18 09:26 , Processed in 0.088790 second(s), 18 queries .
