esab powercut 650 help
发表于 2022-10-9 15:51:47 | 显示全部楼层 |阅读模式
I just bought a used Esab Powercut 650. The machine doesn't make an arc. When I pull the trigger, the air flow runs. I checked for a fault light and there is none. If I disconnect the air, the fault light will light, so I know the fault light works. Is it possible the consumables are just done? Is there a way to check if that is the only problem? Where should I get consumables from, I see them on Ebay and Amazon, is there a best to buy, or any to stay away from?http://www.youtube.com/c/landisperformanceMiller Syncwave 200Lincoln 180 EasyMigEsab Powercut 650
Reply:It's a high freg start machine and no pilot arc. Get it close or touching the work piece to check for function.. I would get some American Torch Tip parts/Profax/Esab on Ebay.for starters..Then you can do China stuff if you like to try some.Esab/Lorch ET-220iEsab 160i caddyEsab CV353Esab 876Thermal LM-200/ Lincoln feedersThermal 60i- 3phaseThermal Pro Power Engine DrivePak 50Thermal 15cINE 1500
Reply:When I was testing the machine, I scratched the tip on the metal and still no arc, and no fault light. What else can I check to see why the machine isn't working?http://www.youtube.com/c/landisperformanceMiller Syncwave 200Lincoln 180 EasyMigEsab Powercut 650
Reply:Check the hi freq spark gap..There is a limited service manual on line, but the tech here in the Forums can get you pointed in the right direction..(ccawqc)Esab/Lorch ET-220iEsab 160i caddyEsab CV353Esab 876Thermal LM-200/ Lincoln feedersThermal 60i- 3phaseThermal Pro Power Engine DrivePak 50Thermal 15cINE 1500
Reply:Ok, I am a newbie to these machines, where would I find the hi freq spark gap, and what size should it be?http://www.youtube.com/c/landisperformanceMiller Syncwave 200Lincoln 180 EasyMigEsab Powercut 650
Reply:Ok replaced the electrode and nozzle and still no arc when touching metal. The plunger has some black marks on it and in the torch where it go, is black under the seat. What is the next thing to check, really need to get this thing running, have a project waiting....http://www.youtube.com/c/landisperformanceMiller Syncwave 200Lincoln 180 EasyMigEsab Powercut 650
GMT+8, 2025-12-18 09:26 , Processed in 0.094904 second(s), 18 queries .
