Boot err
发表于 2022-10-9 15:51:40 | 显示全部楼层 |阅读模式
Trailblazer 325 4 years old starts up no weld output all outlets work . Display shows boot error.  Used thumb drive to reload software gets halfway thru reload then it  stops . Shows error
Reply:This sounds like a board level ROM / PROM / EPROM failure.  Call Miller for advice on whether the chip can be changed or whether you need to replace the whole board.  They are good about supporting their machines.
GMT+8, 2025-12-17 10:56 , Processed in 0.207412 second(s), 18 queries .
