查看: 15|回复: 0
ever see this type of welding ?
发表于 2022-10-9 15:51:38 | 显示全部楼层 |阅读模式
im just seeing this stuff for the first timeinvertig 221 water cooledhypertherm powermax 30xpfronius transpocket 180fronius transsteel 2200fronius iwave 230i water cooled
Reply:Yep, you can buy a TIG cold wire feeder from CK worldwide.  No oscillation on that one, but I'm sure it improves productivity an order of magnitude still.  An even better alternative is the TopTig system by Oerlikon.
Reply:Hotwire can be good for quality since it'll burn off any contaminants. Probably not with those systems though, the high quality hotwire systems have huge wire nozzles with supplementary cover gas to cool the system and keep the wire from oxidizing when it heats up after the contact tip. The ones meant for automation can have water cooled jackets around the contact tip.Tons of companies make those systems, both in hotwire and coldwire, but I'm always suspicious of the lesser known ones who make manual hotwire systems. They tend to look a little janky like this one http://www.tiptig-international.com/AllinOneFeeder.html which is scary. Depending on material/thickness sometimes you run 100+ amps on the hotwire side of the system to preheat it enough, doing that with what appears to be a metal attachment bracket connected to the torch body gives me some pucker factor. It'd be like holding onto the bare metal of a liner or contact tip of a MIG gun while you weld, I'd rather not. Even scarier if that cable they have attached to the bracket is the hotwire line itself since that's an open electrical connection at that point. A cooler process in my opinion is the MIG/Laser hybrid stuff. Ever seen a double sided fillet weld made in one pass?
Reply:i never seen that laser stuff before. i just barely found out about cold metal transfer from watching fronius videosinvertig 221 water cooledhypertherm powermax 30xpfronius transpocket 180fronius transsteel 2200fronius iwave 230i water cooled
Originally Posted by Oscar
Don't need a laser for that.  Just two MIG guns, one in each hand and very steady, precise movements.
Reply:this type of welding machine looks quite high-end.five nights at freddy's
GMT+8, 2025-12-18 18:43 , Processed in 0.093974 second(s), 18 queries .
