Old buzz box mystery
发表于 2022-10-9 15:51:37 | 显示全部楼层 |阅读模式
I just picked up an old welder I have never seen before. Trying to get any information I can since there is no data plate i can find. It has a vertical amp slider on the left front, a or b holes for the stinger to plug in, & breaker on the right. Don't know how to post a pic.Last edited by mystery; 5 Days Ago at 10:59 PM.Reason: Try to add photo
Reply:https://weldingweb.com/vbb/threads/1...post-a-pictureThe harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Does it loo like this?
ThunderBolt 225 Style 706-A4 - IOM-111 Cover.pdf (32.4 KB, 45 views)MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:What color is it?Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Based on the picture I'd say it's an old stick welder.
Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Originally Posted by jpump5
What color is it?
Reply:It's Gray & rectangle shaped. Not tombstone.
Reply:Can't open attachment. It seems this site is not set up for Android phones.
Reply:Sounds like a cracker box.
Reply:Doesn't look repainted. Very dark gray almost black. I haven't seen anything like it with the vertical slider. It's definitely a buzz box stick welder about the same size as the Lincoln tombstone.
Reply:Could it be a Craftsman?
Originally Posted by whtbaron
I think some of the guys using Androids are using Tapatalk to post...
Reply:I take a photo with my phone, send it as an email to my PC. I save the photo to desktop. From there I use third icon from right to follow & attach.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:I think that's very close! Mine doesn't have the extra 4 plug ins only the 2 labeled heat.
Reply:No tree at top for me.
Reply:Yours will be an AC only machine... probably fairly low amperage. I "think" there was some variations of these made by Century (?) for both Sears and Montgomery Ward, but don't quote me on that.
Last edited by whtbaron; 2 Days Ago at 01:48 PM.The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Ok friends I believe the mystery is pretty much solved. It's not exact in that mine is one solid color of very dark gray. No silver in the middle. The closest so far is a Craftsman model 113201260. I even found a overhaul link! It is attached below as a thank you for all of your kind posts. Maybe there's still hope for this crazy world with good people like you!https://jimkerkhoff.com/2019/09/08/h...ftsman-welder/
Reply:Good,,,, the suspense was killing us.www.urkafarms.com
Originally Posted by 12V71
This is what you should be seeing when you hit "reply to thread", the tree is the third icon from the right at the top toolbar.
Don't have a computer. Only android phone.
Originally Posted by Bob E.
Attachment 1744257
I’ve got one of those Buz Box welders.Tried to sell it. Tried to give it away.Now I think I’ll just keep it.
When I picked up my Sears at farm auction, I think I paid around $40 for it. Buzz boxes are handy... now I pretty much keep one in every shed...
Reply:Yea, both of my Buzz boxes had a steady diet of 6013, 7014 and more recently more 7018 AC... always seemed to be able to stick 2 pieces of metal together...The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
GMT+8, 2025-12-18 09:26 , Processed in 0.092623 second(s), 18 queries .
