Finally, I got this big guy!!!!
发表于 2022-9-27 15:52:04 | 显示全部楼层 |阅读模式
This workbench weighs nearly a ton and it was exhausting to install. The welder is also new, i bought it on Amazon. Let me try it if it works, and then I can make something interesting. Do you guys has any good ideas?
Reply:You can start with a cart for the Welder to get it off the welding table
Reply:That’s a nice welding table.You could build something to set your new welder on.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Details on where you bought the table would help. Sent from my SM-G996U using TapatalkMillermatic 252 MIGMiller Dynasty 200DX TIGMiller Spectrum 625 PlasmaAltas 12x36 Metal LatheBridgeport Milling Machinewww.psacustomcreations.com
Reply:Definitely a nice little fab table. A cart should be one of you’re first projects. And I’m guessing that bench is under 1/2 ton
GMT+8, 2025-12-18 17:36 , Processed in 0.089058 second(s), 18 queries .
