Little Grinder Work.
发表于 2022-9-27 15:52:03 | 显示全部楼层 |阅读模式
The root rake will have to wait for a few days. I'll be working in Charlotte, NC at the other yard. I have to gouge and re-plate a grinder. Man the piles were steaming in the cool air this morning. The boys went up last week and tore it apart and pressure washed it for me. Pic 3 is the grinder head setting on the ground. This is one of the larger 1500hp grinders.
Lincoln 330MPXLincoln Power Mig 256Lincoln LN-25X Wire FeederMagnum PRO 250LX GT Spool GunLincoln AC/DC 225¼ Ton of Torches OFC-A OFG-AAir Carbon Arc Gouging CAC-AEverlast 62i Plasma CutterIngersoll Rand T-30 14hpInstagram: #Freebird Welds
Reply:Wow hope you have some good helpRetired Old GuyHobart 210Lincoln AC/DC 225/125 Evolution 14” Saw
Reply:So, does a job that size take 1 or 2 cans of Flex-Seal to fill the holes,,  ??My BIL installed a new grain elevator,, about 115 feet to the distribution head at the top.They told him that grain coming down the pipe would hit the bottom of the truck bed, and bounce out.So, I built an offset box, the grain came into a rectangular box at the left, then there was a hole at the right for the grain to come out.I fabricated it out of 1/4" steel, except the bottom was 1/2" so that it would never wear out,,,,,Well, about one year later, the grain wore a hole through the 1/2" steel plate,, "never" ended up being only one year.My nephew welded on a piece of some AR plate, 1" thick,, that did last many years.Who would guess that grain simply falling in a piece of pipe could wear away 1/2" of steel so quick!!
Reply:I don't have the ability to work fast, and work smart.  I couldn't do that.  I need too much time to think about what to do.
GMT+8, 2025-12-18 14:27 , Processed in 0.089188 second(s), 18 queries .
