Old Sam 650
发表于 2022-9-24 15:51:23 | 显示全部楼层 |阅读模式
I have an old Sam 650, my guess is its about a 1980. I keep it around for big jobs like air arcing or welding new bottoms in loader buckets, etc. So it sits a lot, I went to use it and engine low idles fine but it just barely strikes an arc and won't rap up to high idle. Its the 6 cylinder gas motor. Any ideas on what to look for?Thanks in advance
Reply:my sam400's are slightly newr than ur's, and dont tach up/no exciter, u need to set throttle mechanically.      also, u havent used it in a while, and  the setting are lil confusing, and terminoly is outdated, so double check.         maybe check/shine commentats/armeture up , and brushes .    other than the basics, i dont know much, id be here ;ooking for help too
GMT+8, 2025-12-18 08:59 , Processed in 0.066141 second(s), 18 queries .
