Firepower FP-200 vs Primeweld 180
发表于 2022-9-21 15:51:21 | 显示全部楼层 |阅读模式
Looking for some advice as I'm unsure what to prioritize. Sorry in advance for such a long post.I'm going to buy my first welder for hobbyist projects. Things on project list will be: PC case's with 14 gauge sheet metal. Office desk and occasion furniture. I would like to eventually attempt off road/ over landing mods and maybe front bumper. The thickest i plan for currently is stands and mounts for active shooting targets at 1/4" or so.While I will primarily be working with thinner pieces, I want a unit capable of handling thicker metal so I can do it all with one welder. The priority in my mind is choosing the unit that produces the best welds possible.Welder specs:------------------------------------------Firepower FP-200ESAB designedTheir 3yr warranty10 ft. Tweco Fusion 180 MIG gun with Velocity consumablesFirepower/Victor GF250 gas regulatorFunctions: MIG inductance, wire run-in, wire burn-back time, and pre/post gas flow settings. 2T/4T welding modesInfinitely adjustable15 percent @ 200 amps22 gauge up to 3/8-inch------------------------------------------Prime weld 1803 year warranty Tweco 100 style torchAluminum spoolStick weld capabityShielding Gas Pre-Flow and Post-Flow2T/4T Torch Trigger Lock30 percent @ 180 amps60 percent @160100 percent @ 100 amps>= 22 gauge (no max mentioned)---------------------------------------------Questions:1. Are the features such as MIG inductance, wire run-in, wire burn-back time missing from primeweld offering? How import are they?2. Does the primeweld have infinite adjustability? Is that important?3. 200A low duty cycle vs 180A not as low duty cycle better?
GMT+8, 2025-12-18 13:50 , Processed in 0.096905 second(s), 18 queries .
