2050
发表于 2022-9-20 15:51:21 | 显示全部楼层 |阅读模式
I have the 2050 and all of a Sudden does a couple cuts and stops. shut it off, both the power light and the ready are on regular like and make 2 cuts and it simply blinky on the power light and no cut.  I had the torch apart, the blow back parts, changed tips even.  It worked a bit after I fiddled it up so I assume its something in then torch giving it fits.  I think it has the stock 55 thing on it, I really dont know 1 from another and maybe there is an improvement?www.urkafarms.com
Reply:You're simply 28 years early...
GlenRed-D-Arc EX300 (Miller XMT304)Hobart Champion 16Hobart Hefty CC/CVHobart Handler 140Lotos LTP5000D
GMT+8, 2025-12-18 09:55 , Processed in 0.089486 second(s), 18 queries .
