SP 125 Plus
发表于 2022-9-20 15:51:21 | 显示全部楼层 |阅读模式
Good morning all!New to the forum, and never welded before so I obviously signed up to this forum to gain some knowledge before just diving in and causing myself grief/harm/disgruntlement to the point of never returning to welding.Quick question - my father in law passed recently and my mother gave me his sp 125 plus.   He and I had been talking about me coming down (different cities) and teaching me how to weld.  I have been interested for some time and never found the time.  What I would like to start with is a bunch of aluminum.What I know is to pick up a spool gun and use 5056? wire.   Thicker heavier wire to reduce the feed issues.Couple of basic questions and feel free to offer any other quick things that come to mind please.   I don't know what I don't know to ask.  I don't mind spending the time to look it up, if it's a bunch to type up but it's important.  Pointing me in the right direction is absolutely appreciated!Three quick questions:I need to know what spool guns are compatible.   When I look on Amazon, and on the web they list many models which look to be newer than the one I have and I can't seem to find a spool gun for the sp 125 plus, and not sure if I can just use any gun that works with the 140.With aluminum specifically and a spool gun.   If there was one thing you wish you knew before you started what would it be?How does using a spool gun alter the way you approach welding?Again, much appreciated on any information.   Enjoy the day!James
Reply:Good read until someone answers your questions https://weldingweb.com/vbb/threads/9...oln-SP125-Plushttps://weldingweb.com/vbb/threads/1...s-and-aluminumLast edited by precivilization; 18 Hours Ago at 08:59 AM.
Reply:This is a hard way to start out, like picking up the middle of the book to learn trig.  The 125 is fine but its a steel machine.www.urkafarms.com
Reply:i have a sp125.  it has and still is used for steel welding up to 1/8" metal and auto body sheet metal.  imo its not powerful enough for aluminum except sheet.  i did ALL my body welding with it.  in different shops over the years many different size welders up to miller mig 250 amp, the sp125 was the best and most controllable.lincoln 125spdayton 250 ac/dcmiller 211 w/spool gunahp  200 sx tiglotos ltp5000dkubota b3200 FEL BHof course duramax diesel
Reply:Its a really good body machine. I am looking for a 135-140 now.  I want smaller wire on hand and the settings are exactly the same as the larger one.  Can weld down to paper thickness with it and 023.  Really nice for exhaust work.  Its just another level you can turn the current down and have machine still weld correctly.Last edited by Sberry; 10 Hours Ago at 05:36 PM.www.urkafarms.com
Reply:I doubt the machine is spool gun compatible.   Its nice to get a free machine but 2 things with starting out.  First, why the "bunch of aluminum" ?  This is hard first and its really a steel world.  Yes you can find alum work if ypou try hard enough bit in decades find onlyu a handful of times with stuff most people dont own that get in my way in regards to alum while doing 50000+ welds with 1 machine alone on steel.www.urkafarms.com
Reply:Keep this on steel, use 023 for light work and buy a new 240V or DVI with spooly right out of the box in a package deal.  Put 030 solid in if for light fab and hook the spooly on if and when you need it, invest in gas bottle for each machine, acts as spare.www.urkafarms.com
Reply:With a aluminum type liner it can weld aluminum. Problem it's will be great for tack welds only.There was a guy doing production aluminum back in the day,   The SP-125 is a nice auto-body rig, and exhaust type work. A machine like a Klutch 140si with spool-gun is light years ahead of the Lincoln in laying beads down..I would like to have a SP-125/135 in my shop. I have a love affair with those old Lincolns..
Esab/Lorch ET-220iEsab 160i caddyEsab CV353Thermal LM-200/ Lincoln feedersThermal 60i- 3phase Pak 50Thermal 35CThermal 15cINE 1500 Klutch 220iBlue Demon/140 msi/90sti
Reply:i managed to do some alum welding on a swingset repair  in a kids park once w/ my sp135, and a couple other thin jobs before i a better setup.      i never t4ried a teflon liner, but i zip tied a 9' piece of skinny rebar to the gun, to keep it straight.        like said, the 110v lincon minimig lacks power.       as far as spool gun compatible, i think it can be made to happen, cuz,    there was a guy on here yrs ago, that gave step by step info and pics of making his 170 or 175 lincoln mini mig, adapt to a spool gun.     it appeared to be a really nice clean job,  he put a toggle switch and a green notification light on it.Last edited by 123weld; 5 Hours Ago at 09:53 PM.
GMT+8, 2025-12-18 10:45 , Processed in 0.088906 second(s), 18 queries .
