Multimatic 255 - Strange Feed issue?
发表于 2022-9-18 15:51:25 | 显示全部楼层 |阅读模式
@louie1961 Today I set it to manual to get a better feel for the bead behaviors, and I encountered a weird condition. I thought maybe you might know a solution to it.Gas flow happens, but wire does not feed and no arc in manual mode. In autoset it feeds and arc happens.Settings c10, 17V 270 IPM, Arc 70. I've changed around the arc setting a few times now. I'll set it back to default 50 but that shouldn't stop it from feeding.Oddly enough in autoset/synergic or autoset pulse it does fine but until today i'd not tried it manual. Any ideas?I'll go back to the struggle bus with the autoset mode although I don't like it, I hope to get this sorted out. Miller & Airgas are not going to be taking my calls on the weekend.
Reply:No clue. That is weird. I would call Miller straight away.
GMT+8, 2025-12-17 08:42 , Processed in 0.097748 second(s), 18 queries .
