multiprocess welder
发表于 2022-9-17 15:51:21 | 显示全部楼层 |阅读模式
what is the best and cheapest multi process welder?
Reply:How much money are you willing to spend?How thick of material are you going to weld?You have to buy the welder, one and maybe two cylinders, helmet, clothing, table, clamps, grinder, tools, etc as well.Millermatic 252 MIGMiller Dynasty 200DX TIGMiller Spectrum 625 PlasmaAltas 12x36 Metal LatheBridgeport Milling Machinewww.psacustomcreations.com
Reply:So what you are really asking is TWO questions?  BestCheapest If it is ONE question, where exactly do you wish to draw the line as far as “best” and “cheapest “?:
Reply:i suppose we would need to make two lists  of all the MP welders currently available :one would be listed in order of the number of good reviews available for that machine the second would list the welders starting at the cheapest list price and working up to the most expensive the welder closest to the midpoint of both lists would be your answer. good luck in your search.:
GMT+8, 2025-12-18 13:53 , Processed in 0.065784 second(s), 18 queries .
