2x4 shaded cover lense
发表于 2022-9-17 15:51:20 | 显示全部楼层 |阅读模式
Hey there. I'm curious if there is such a thing as a shade 1 cover lens for the 2x4 fiber metal helmets. I cant seem to find any.Sent from my SM-A530W using Tapatalk
Reply:I've never seen one.... just shades 5 to 13. If you want to add it to move you up a shade, I think your best bet would be to switch to a decent auto-dim with adjustable shades 5-13. If you really want to run it alone, it wouldn't offer you much more protection than a decent pair of UV sunglasses.The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Back in the 1970's they had #3  but replaced by safety glass with tint.Dave
Reply:There are many different shades to pick from :
regards
Airco 250 ac/dc Heliwelder Square waveMiller Synchrowave 180 sdMiller Econo Twin HFLincoln 210 MPDayton 225 ac/dcVictor torchesSnap-On YA-212Lotos Cut60DPrimeweld 225 ac/dcPrimeweld mig180Miller AEAD-200
Reply:Buy a replacement lens for a face shield and cut one out of that. As mentioned, shade 1 would be no different that sunglasses.If you try cutting a face shield, I recommend using an abrasive cutting wheel or maybe even a hot knife. They're liable to crack otherwise.Sent from my Lincoln Buzzbox using Tapatalk
Reply:Just wearing sunglasses under the hood would be the quick and dirty solution to see if it would even help.The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Originally Posted by NRLwelding
Sunglasses work but a pain in my ***
Originally Posted by 52 Ford
Pro tip: Weld for a while without a hood on. After that, the shade 10 will be plenty dark enough.
Reply:A lot of things have changed and I used to have a safety paper on it but mixing tinted lens to get different shades is not a recommended practice can’t remember all of it guys used to mix shades in flip up hoods to cut and weld 7 & 3 made a ten ? 6 & 4 made a ten ? But technically that paper I had said it didn’t ? Like I said a lot has changed in lens over the years it might not be valid any more
Reply:My wife is an optician & her office used to have the solutions and equipment to tint lenses, it might be worth a try to check with a few opticians.NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINELET'S GO BRANDON!"Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
Reply:Try this for welding and cutting torch https://www.mcmaster.com/5783T2/Also good for poor eye sight Dave
GMT+8, 2025-12-18 08:56 , Processed in 0.162099 second(s), 18 queries .
