查看: 14|回复: 0
My First 2 Welds
发表于 2022-9-16 15:52:34 | 显示全部楼层 |阅读模式
First welds since the cataract surgery.I haven't attempted an uphill weld of any kind in a very long time.  I simply couldn't see anything but a huge glob of light.  I may have done a few round welds back when I made the pipe stands, but they were flat welds I believe.The Warm Up Swing
Stepping Into The Box
The first weld was loose, and nervous.  Arc too long, carrying too much metal, and generally not a best effort.  But it gave the feel for it again.The second weld was better.  Tight arc, more attention to the puddle, generally more relaxed.  A stringer more properly sized for the diameter of the rod.  I haven't seen an uphill puddle clearly in such a long time, it was a relief.I really don't believe in bench practice.........just weld what you have to weld.  It's better practice to do the real deal.Anyways.............at least it's a start back to a normal work life.  I'll never be the artiste some guys are, but it's coming back to a workable level.3/32 Excalibur at 85amps.
Reply:Good thing taking care of your eyes.  "One of these days" I need to take care of my eyes.  Been reaching for the readers a lot more often lately and the floaters visit more often than they used to.
Reply:Those will hold!  I love 3/32 uphill for pipe and smaller structures.We've done so much, for so long, with so little. Were now qualified to do anything with nothing !
Reply:Soooo, are we to presume you'll be looking to grind out some previous welds to redo them now that you can see again?
MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Don't ya wish you'd done it a long time ago??NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINELET'S GO BRANDON!"Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
Reply:Sam,I am thrilled that you are able to see what you are welding again.-DonSmith Oxyacetylene TorchMiller Dynasty 200DXLincoln SP-250 MIG WelderClausing/Coldchester 15" Lathe16" DuAll Saw15" Drill Press7" x 9" Swivel Head Horizontal Band Saw20 Ton Arbor Press BridgeportLincoln LE  31 MP & Lincoln 210 MP
GMT+8, 2025-12-18 09:55 , Processed in 0.089985 second(s), 18 queries .
