查看: 14|回复: 0
Big bale fork
发表于 2022-9-16 15:52:34 | 显示全部楼层 |阅读模式
Had a little problem. Was going to just replace the cross 2" X 4" piece with new until I priced it then decided on doing it this way. it'll work and be stronger.
Trailblazer 302Hobart Stickmate AC/DCLincoln SP 135 TSmith torchSpoolmatic 30A
Reply:That's a very sensible repair.  I think we're all finding ways to use less steel these days.  It's so damn expensive!You, and everybody else, knows that I can't weld round stuff worth a hoot.  I like the way you switched from stick on the straight welds, to wire on the round weld.  I'm able to control the shorter gun in a round situation much better than I can control a stinger.  I just don't have the muscle memory/skill for round things.I was watching an IC Weld video, and noticed that he will take the stinger, and point the rod straight down around a round flange, or whatever, and keep it straight as he moves it around the piece.  Makes for a very nice looking weld in something that isn't absolutely needing a deep throated fillet.  I tried it the other day, and was fairly pleased with the result.  Anything that improves my circular welding abilities is a God Send.BTW............you're not supposed to try lifting pickup trucks with those bale spikes
Reply:Anyways, it looks like wire on the Conus fitting?????????????
Reply:Na it's stick all the way out. I watch I C weld all the time and am more amazed every time, especially his torch work.Trailblazer 302Hobart Stickmate AC/DCLincoln SP 135 TSmith torchSpoolmatic 30A
Reply:Isaac is A+++
GMT+8, 2025-12-17 08:53 , Processed in 0.120774 second(s), 18 queries .
