Lincoln 250
发表于 2022-9-16 15:52:32 | 显示全部楼层 |阅读模式
Hello I have a lincoln 250 single dial. The 110 outside work fine the 220v runs mu mig fine but if I run welder for like a hour then go to stick weld or have been stick welding it hardly has any juice to strike a arc nothing more but maybe strike it can turn it off let to cool down then welds fine until it get hot again. Anyone know where to start or what it could be. Thanks in advance
Originally Posted by danielplace
120 and 240 voltIs the fan running ?You sure your not exceeding the duty cycle and overheating the machine ?
GMT+8, 2025-12-18 09:24 , Processed in 0.088638 second(s), 18 queries .
