Any thoughts on the new MicroCut 45 DV Plasma Cutter?
发表于 2022-9-16 15:52:31 | 显示全部楼层 |阅读模式
I know that they're not actually available just yet, but I was still looking for thoughts from the board about the new plasma cutter vs comparable models available out there?  We run a sawmill operation complete with heavy equipment, so, basically, having the ability to cleanly cut up to 3/4" steel is the basic requirement.  Beyond that, it would be very nice to be able to make lower quality cuts up to 1" in thickness.I would also greatly appreciate any information about the dos and don't of setting up a line dryer system that can be used effectively with a plasma cutter.Thank you kindly for your time.I believe that banking institutions are more dangerous to our liberties than standing armies. - Thomas Jefferson
Reply:My plasma cutter will clean cut to an inch and sever 1 1/4". I use it mainly 1/2" and less cause nothing beats oxy-acetylene 1/2" - 4" in speed and clean cut.Now for your question. Here in South Carolina my 25cfm / 175psi Ingersoll Rand can produce up to a quart of water a day. Since I started using that Milton setup with 2 air cleaner/filters I have yet to see any moisture/water while blowing, arc gouging, air tools or plasma cutting. I use an inline oiler or manually oil my air tools when needed. I was more concerned about moisture/water removal and that is why I set mine up the way I did. Now when I dump the tank at night I get my quart of water.
Tank drain.
Last edited by Freebirdwelds; 1 Week Ago at 06:45 PM.Lincoln 330MPXLincoln Power Mig 256Lincoln LN-25X Wire FeederMagnum PRO 250LX GT Spool GunLincoln AC/DC 225¼ Ton of Torches OFC-A OFG-AAir Carbon Arc Gouging CAC-AEverlast 62i Plasma CutterIngersoll Rand T-30 14hpInstagram: #Freebird Welds
Reply:Funny story. I had to read Freebird’s post before I consciously realized I ALSO prefer using a cutting torch (as opposed to plasma cutter)  for anything over 1/2”. I’ve never cut anything close to 4” though. That’s big boy territory. LOL
Sent from my iPad using Tapatalk
Reply:Since you will be near its max, what is the duty cycle?    Looks like it is out of stock,also.I have an old thermal dynamics 45.  I like it when I need it.
Reply:Freebird .... Is the last photo you posted showing the drain line from your Ingersoll Rand T-30 compressor?I believe that banking institutions are more dangerous to our liberties than standing armies. - Thomas Jefferson
We used to have a fellow who took care of the cutting for us, but he's since retired...so, along with his work truck, his gas setup is no longer available.  In addition to that, our local welding gas supplier tells us that they haven't had any gas bottles to sell for months now; hence, our interest in purchasing a plasma cutter.  It would also be a rare occurrence for us to cut anything over 1" in thickness, so I'm thinking that the right plasma machine should be of good use to us.
That totally makes sense. However my take on your situation is if AT ALL POSSIBLE budget for a bigger machine than what you are contemplating. Being “able” to cut 3/4” is not the same breezing through the material with a machine with more capacity. Sent from my iPad using Tapatalk
Reply:you are welcome but i am not the one to ask. others here will be more up to date with quality plasma cutter options.  let us know how you make out!:
Reply:Cutmaster 60i would just get you there.. 60 amps.. Hypertherm 65 would be a bit more power,and work on 1 inch somewhat better.. The 3/4 on both will make as nice of cuts as any O/2 setup. (both will Pierce 3/4 by hand very fast.and easy) 1 inch with the same speed and cut quality as O/2 (12/13 IPM) will be in the 80/90 amp range.. 4 IPM on the 60i.Esab/Lorch ET-220iEsab 160i caddyEsab CV353Thermal LM-200/ Lincoln feedersThermal 60i- 3phase Pak 50Thermal 35CThermal 15cINE 1500 Klutch 220iBlue Demon/140 msi/90sti
Reply:Seems like a good value at 50 % in welding.  Doing the math inch/min vs your pattern.  Not sure how it translates to plasma cutting.  Perhaps “somebody”  on here has one???Are looking to hand cut? Or table setup?
Originally Posted by Oscar
Originally Posted by Brand X
Looks very Chinese to me..   I guess if you want to save a bit of money over a Hypertherm 45 XP it would make sense. It's performance with with that torch design will be major downgrade..
Reply:I just wish they stayed with something from Italy. You could get some fantastic torch consumable designs that would compete with the top tier units..You are looking at about $500 less then a 45xp and the torch upgrade/ 1 year longer warranty goes to the Hypertherm. Plus, why build your future on going down the China rabbit hole? I am  ok with the bottom feeder china stuff because there really is value. When it gets into the thousands of dollars it starts to make almost no sense to roll the dice on such high $$$ stuff.(IMO)Esab/Lorch ET-220iEsab 160i caddyEsab CV353Thermal LM-200/ Lincoln feedersThermal 60i- 3phase Pak 50Thermal 35CThermal 15cINE 1500 Klutch 220iBlue Demon/140 msi/90sti
GMT+8, 2025-12-18 09:54 , Processed in 0.085397 second(s), 18 queries .
