330a/bp stopped working
发表于 2022-9-16 15:52:31 | 显示全部楼层 |阅读模式
I turned on my 330a/bp today to do a little tig welding.  When I flipped the switch it came on for a second then completely shut down.  I have power to and from the switch.  When I check voltage at the circuit breaker  I have 22v on both lines in and out.  I also have 22v to and from the fuse.  Does anyone know what this might suggest my problem could be?
Reply:Did you try on the Miller site? There are a few techs there that might be able to advise you.https://forum.millerwelds.com/forum/welding-discussionsThey will likely want the serial number to find the correct information.---Meltedmetal
GMT+8, 2025-12-18 10:21 , Processed in 0.089713 second(s), 18 queries .
