High ideal problem
发表于 2022-9-16 15:52:28 | 显示全部楼层 |阅读模式
Got my new low ideal bored and it ideal up when you have a grinder running but when your strike an arc it still won’t I replaced the reed fuse as well any idea what it could be? Sent from my iPhone using Tapatalk
Reply:Just a wild guess but are you sure polarity is correct? Also check weld polarity.
Reply:Will the idler switch still make it throttle up?Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:I trust you inserted the new reed switch into the fiber tube that is wrapped with the copper strap.Did you get a new switch with the leads already soldered on?  If you had to solder them on, it's easy to overheat the switch which can warp the switch internal components rendering it inoperable.  You can test the switch by checking for continuity between the two leads when an arc is struck.If the above is yes, make sure the switch lead going to chassis ground is making good contact.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
GMT+8, 2025-12-18 09:24 , Processed in 0.093804 second(s), 18 queries .
