Spoolmatic 1 CR2 relay wiring Help Millermatic 200
发表于 2022-9-16 15:52:23 | 显示全部楼层 |阅读模式
Hello to the Forum, I have searched under every key word I could think of but did not locate anything on this subject.I have a MillerMatic 200 SN:JD731885 that welds just fine with the mig gun.I purchased a Spoolmatic 1 (4 Pin) that plugs right in on the front.When the trigger is pulled the wire feeds (and the wire speed control works on the gun).The gas flows.The CR2 relay activates but the contactor does not.If I pull the mig gun trigger, the contactor activates.I have the manual from Miller but it does not show the pin out and wiring to the pins on the CR2 relay.I replaced the CR2 with a new one and no change., and I suspect it is not wired correctly judging from the photos I’ve been able to come across on the internet.I have followed all the wires, checked for continuity, check all connections for corrosion and tightness.Does anyone have the pinout and which wire to the pin on the CR2?All the wires are nicely labeled.I really searched trying to find any info on this and came up empty.Any help would be greatly appreciated.Thank you for reading this.
Reply:Here's a link to the Manual Miller says corresponds to your serial number. The Spoolgun connector (shown in the bottom Parts section, Page 10) is called RC3 and is near the top left of the schematic where the letters C, A, D, and B line up (top to bottom). That's in Fig. 6-1 on Page 28. CR1 and CR2 are both shown in that area..Last edited by Oldiron2; 1 Week Ago at 01:12 AM.
Originally Posted by robertnobody
Thank you for the fast reply. I have that manual and have found the relays on there and the plug pin out, but I can not find thepinout for the relay itself. the relay has 8 pins on it with 7 of them occupied with a wire. A with wire #387 with wire # 344 with wire # 371 with wire # 1on the other sideB with wire # 349 with wire # 26 has no wire connected3 with wire #18Pin A and B have a jumpered diode between them. Im not convinced this is correct and from photos I’ve seen looks like there’s a wire connected to pin 6what I need is which wire goes to which pin to verify correct hook up. This is how I found the wires but not to say they were in the correct locations. Robert.
Reply:Yes, schematic is the same one. pin A of the Spoolmatic plug is Wire# 37 which goes to a pigtail at a resistor,  the other end of the pigtail goes to pin4 on the CR2 relay ( this is also labeled wire#37)going through the resistor is then wired to a compositor and the wire # 39 coming out of that going to pin C in the Spoolmatic plug.  Pin D on the spoolmatic plug is wire # 38 which goes to pin A on th CR2 relayI have no idea if the wires are on the right pins on the CR2 relay. I am hoping there is a Service Level schematic or relay pin out that someone may have to show this.
Reply:Oldiiron2,THANK YOU , THANK YOU THANK YOU!!!!!!!!i took your advice and traced all the CR1 circuits and figured out which two wires where on the wrong posts of the CR2 relay.SHE WELDS ALUMINUM !!!!!!!!!!!!!I purchased this Spoolmatic 1 off of eBay that had not been used much if at all.Ive spent some hours trying to figure this out, now to replace a hundred zip-ties on all the wiring.This forum is really awesome.Thank you for the advice and knowledge, and thank you for the fast replies.Robert.
GMT+8, 2025-12-18 13:59 , Processed in 0.101000 second(s), 18 queries .
