Amazing!!
发表于 2022-9-16 15:52:21 | 显示全部楼层 |阅读模式
Some of y'all will know what this is for
Absolutely amazing!!
Reply:Just one eye for now?Lincoln, ESAB, Thermal Dynamics, Victor, Miller, Dewalt, Makita, Kalamzoo.  Hand tools, power tools, welding and cutting tools.
Reply:Been there, wore the eye shield too. Glad you got it done. So much better, right!? You’ll likely still need readers.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 120www.10FtDrillBit.comwww.MyWelds.com - pictures of my work
Reply:i've had cataract surgery and never had those shields.  i had no idea what the heck that pic was of. loli was careful to park my truck around the corner and not right in front of the clinic reception area. you're supposed to arrange a ride home and i told them i had a cab waiting.
Reply:I'm so relieved... if that was something you were supposed to shove in a cow, I didn't want to know...The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:thought it was the piece out of the bottom of the urinal thought farmersammm was having a beer night was wondering what the paper was for lolDo not argue with an idiot. He will drag you down to his level and beat you with experience.
Reply:I'm not totally sure that I could have driven home safely, but in a pinch, I guess so.We came to the same agreement as when I had the lung biopsy.  They inserted an IV line so that a sedative could be given if need be...........but no sedative was given prior.  It was just to be used in an emergency if I got froggy.  (I wanted to be able to wear my own N-95 during the procedure, they put you on O2 if they've used the sedative)  It was a bit of a PITA to get it across that I didn't want anything but Lidocaine on the eye, but they were decent about it.They strap you to the table, literally
  Then put a tight rubbery band around your forehead, and cinch it down to the table.  Which I think is great.  Anything to keep you from moving while they're messing with your eye is fine with me.  I was as stiff as a board anyway, so no worries
Sticky piece of plastic on your face, scrub down, and the guy starts.  They put Lidocaine gel on the eye.  Said to focus on the light, and I did.  3 lights in a triangular shape.The results were absolutely IMMEDIATE.  I could actually see every detail of the ceiling tiles above the table.The vision went to Hell about half an hour later, and didn't improve until around supper time.  The guy said this would happen.He called in the evening to see how things were going.  No problems.  Got reminded to wear the patch while sleeping (already used it  when we got home, and I took a nap).He says that some patients don't bother getting the better eye done if the improvement makes life easier.  I'll decide later.  I imagine the second eye will still be a PITA in bright light due to the cataract,, even though the vision is 20/60.The color rendition is different between the 2 eyes.  I asked about this, and the guy said that the eye that still has the cataract will always "see" with a yellow tint.First time, in a long time, that I can comfortably walk without worrying about where to put my feet.  I'd lost all depth perception.No lifting anything over 20# for 10 days.  This might be a good reason to do the other eye after the hay's in.  The front end requires a lot of lifting, and the roller definitely requires some serious lifting at odd angles.  And.........K'kins already has me on a strict diet of veggies with supper........she says I don't need any straining in other areas
Shoulda done this years ago
told you so.
Originally Posted by 12V71
Lots of us did...
*WE   told you so
Reply:So glad to hear you shared the same results the rest of us had and predicted.  Shouldn't be any question as to whether or not to do the other eye when feasible to do so.Won't say "told ya so" seeing as you've had a bunch already.  See what I did there?
MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Cataracts are the leading cause of blindness accounting for 50 percent of blindness worldwide.   Third world countries having the majority of cases. Here in Canada basic cataract surgery is usually done in hospital and covered by our health care system and as such available to all who need the procedure. There are charitable organizations that help with eye surgeries for those less fortunate if one was able and inclined to donate.
Originally Posted by psacustomcreations
Congrats to Sam for finally getting his eye fixed. If the members here were right in the advice about getting the cataracts fixed,  "imagine all the other times they may have been right with their advice"
I sat and looked at K'kins all through supper this evening.
Reply:I think Sams point was he was glad to be able to clearly see KKins after a long time. He just enjoyed being able to look at her.From Sam's posts, it is clear he still dearly loves KKins. I will give Sam a hard time for the way he doesn't  take care of his health and his equipment. But I would never give him a hard time over how he feels about KKins. Sent from my SM-G996U using TapatalkMillermatic 252 MIGMiller Dynasty 200DX TIGMiller Spectrum 625 PlasmaAltas 12x36 Metal LatheBridgeport Milling Machinewww.psacustomcreations.com
Reply:Congratulations on the cat surgery!  Like so many here on the forum, so glad you had it done.  As soon as you can be cleared, do the other eye since you know now how easy it is.
BTW, after both my wife and I had both our eyes done, we found that colors were much more brilliant and true, and blues were outstanding.
Next up---a  HEARING AID!
sorry, sammm  i couldn't resist
Reply:My wife had her cataracts done and when she looked in the mirror she screamed.  “I aged 10 years!”  She wanted to know if the doc could put the cataract back in
Reply:One problem...............  There's always a problem
I had a very bad halo around bright light at night with the cataracts, and thought I'd lose that with the surgery.  I couldn't drive at night.Now I have a stinkin' starburst effect around lights at night.  I was never told about this, and I'm not thrilled.  If this doesn't go away with time, I'm still unable to drive at night
Originally Posted by 52 Ford
Try wearing some yellow glasses. They won't cut out the glare completely, but a lot of the "harsh" light is blue light - that's what yellow glasses filter out. Actually, yellow glasses are good for a lot of situations. If you're staring at a computer for long periods of time, yellow lens can help with eye strain. On both my phone and my laptop, I have the blue light turned down. You don't really notice it on the screen, blue is still blue, just not AS blue. Try it - seriously! Note that I linked to safety glasses. https://www.amazon.com/s?k=ansi+z87....ref=nb_sb_noss
Blue blockers don't help with the after surgery halos, but with time they go away. It's just a readjustment process and takes time.
Reply:My eye's were done several years apart like at least 5 to 7 or more years apart and the lenses they used changed over the years so they could not use the same type of lens several years later.  This caused me to see the road signs in one size font in one eye and a different size font in the other.  It took about a year or so to get over that.  Your brain adjusts but if I close one eye and look then do the opposite I can still notice it.  It bothered me like crazy at first.Oh anyway give it time and make sure you talk to your doctor about anything you notice.  Example, eyes staying red or in pain for too long like longer than a couple of days.  Having a film that causes cloudy vision at any time during the day or night.Most important is to use your eye drops as prescribed and show up to the follow up visits.Lincoln, ESAB, Thermal Dynamics, Victor, Miller, Dewalt, Makita, Kalamzoo.  Hand tools, power tools, welding and cutting tools.
Reply:Try the orange/amber glasses, they help a lot with glare, just think how scary(for the rest of the drivers on the road) it was just driving in the daylight.NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINELET'S GO BRANDON!"Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
Reply:sammm a few weeks before cataract surgery...
Reply:Just had my left eye done yesterday, took all of 15 minutes max, makes quite a difference for the good which I was told will only get better. Should be a month or so and I'll get the right done.....Mike
GMT+8, 2025-12-17 10:54 , Processed in 0.066460 second(s), 18 queries .
