Root Rake.
发表于 2022-9-16 15:52:20 | 显示全部楼层 |阅读模式
Finally back at it. If I had to weld one more hand rail or garden chair.......Man this root rake was in dire need of repair. To bad I only had half a day to get it done. It was snapped in half in 2 places on the top and a few cracks.In one of the pic's you can see the grinder being hauled of. I got the root rake  done just in time for it to get hauled off to the jobsite. We'll see what tomorrow brings.
Lincoln 330MPXLincoln Power Mig 256Lincoln LN-25X Wire FeederMagnum PRO 250LX GT Spool GunLincoln AC/DC 225¼ Ton of Torches OFC-A OFG-AAir Carbon Arc Gouging CAC-AEverlast 62i Plasma CutterIngersoll Rand T-30 14hpInstagram: #Freebird Welds
Reply:Looks like it needs to be fish plated to carry the stress away from your welds.🤪
Reply:I agree 👍 Dave
Originally Posted by Freebirdwelds
Old wives tale. lol
Not really in all the years I've been repairing heavy equipment I've never had a failure yet. That's 3/4" AR 400 and with a 400º preheat they never fail. After I weld one side I gouge weld the other side. They have 9 of these rakes and every new crack is in a new spot. Now I did put a 4" x 5' x 1/2" AR across the front to help clamp it back into a sorta straight line and welded it 100%.I don't even (fish plate?) plate cracked/broke booms and never a failure yet and those 25 - 30 ton excavators put a lot of stress on anything I do to them.
Reply:We built one out of mild steel angle iron years ago... 70 hp tractor bent it on the first rock... Didn't know what AR 400 was. I think it's still leaning up against a tree somewhere, I should cut it up for iron..The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
GMT+8, 2025-12-17 07:26 , Processed in 0.140456 second(s), 18 queries .
