查看: 13|回复: 0
Blade recommendations
发表于 2022-9-16 15:52:16 | 显示全部楼层 |阅读模式
Hi,I use a portable bandsaw a lot, mostly for cutting ½” gas barrel and 3mm plate. I use Milwaukee blades at present 24tpi but they just don’t seem to last. They either break at the weld or start cracking along their length and eventually give up! The machine is a Milwaukee and takes 44-⅞” blades.Any alternatives greatly appreciated..Tia
Reply:That is a problem with all blades.The wider the blade is less of problem.I have found less tension less breakage Dave
Reply:I never break portaband blades unless binding or other operator error. Seam breakage is unusual.  I usually use Morse , Lenox or Milwaukee.  I prefer coarse blades 10/14 bimetal for hand cutting. Finer blades are too slow for me.  Breaking at the weld is a blade defect.  They may be warranties.
Reply:These are pretty good Morse Master Cobalt Bi-Metal Portable Band Saw Blade 44 7/8 x 1/2 x .020 10/14 TPI 3/Box (001175 / ZWEP441014MC) https://a.co/d/1Zxlthz
Reply:Thanks, I have just discovered a fairly local company that with custom make me some and I have opted for bimetal variable pitch. I’ll see how they go against the Milwaukee..
Reply:I've had excellent results wit Imachinist blades from AMAZON, they're bimetal and available in variable pitch.NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINELET'S GO BRANDON!"Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
GMT+8, 2025-12-18 08:56 , Processed in 0.094868 second(s), 18 queries .
