查看: 15|回复: 0
Prime weld max cool 3000
发表于 2022-9-16 15:52:14 | 显示全部楼层 |阅读模式
Does anyone have one of these on the lower shelf of HF 350 lb. Vulcan welding cart?The Prime weld tig 225x fits on the top shelf from pictures I have found. Sent from my iPhone using Tapatalk
Reply:The Harbor Freight cart looks a little tight from just looking at it. The Eastwood cart looks a little bigger on the bottom shelf, but it is a little more expensive. As I've been told many times measure twice, and buy once.
Holds 2 welders and gas bottles, plus consumables for easy movement around the shopNEW - 30% thicker rear axle shaftNEW - Stronger wheels with 65% wider hubCart holds up to 400lbs. - 2 welders, 2 large gas bottles and consumablesRolls around shop easily on heavy duty wheelsFor MIG, TIG or stick welders and plasma cuttersStores up to 6 tubes of TIG rod3 hooks for hanging welding leadsAdditional room for torches and consumablesSpecially designed top shelf allows access to MIG side panelTop shelf: 21 inches long x 13 inches wideBottom Shelf: 24.5 inches long x 16.75 inches wideLower shelf for welders up to 21.5 inches tallAssembly requiredRegards
Last edited by albrightree; 1 Week Ago at 04:36 PM.Airco 250 ac/dc Heliwelder Square waveMiller Synchrowave 180 sdMiller Econo Twin HFLincoln 210 MPDayton 225 ac/dcVictor torchesSnap-On YA-212Lotos Cut60DPrimeweld 225 ac/dcPrimeweld mig180Miller AEAD-200
The cart is from Northern Tool, had to bend the front lip down to fit the cooler and move the middle shelf up a little. Other than that, works great
Reply:the hf carts are cheesy junk if you ask me. for probly not much more money you can make your own however you want and get free practiceinvertig 221 water cooledhypertherm powermax 30xpfronius transpocket 180fronius transsteel 2200fronius iwave 230i water cooled
Reply:Just went and measured it, it’s wide enough but not tall enough underneath. I’ll be looking at the other options. Sent from my iPhone using Tapatalk
Reply:This one looks like it will work also.
Reply:Looks pretty close. The upper shelf may be able to be raised the inch or two at most it would need to fit.The cooler is only 14" tallhttps://www.harborfreight.com/350-lb...art-56191.htmlhttps://primeweld.com/products/maxco...h-water-cooler
GMT+8, 2025-12-18 15:52 , Processed in 0.113357 second(s), 18 queries .
