Mig welder that is AC
发表于 2022-9-16 15:52:13 | 显示全部楼层 |阅读模式
Has anyone ever come across a mig that was AC output,if so how does it weld compared to our usual DC sets, is there anybenefit to a mig being AC at torch, or is it a waste of time,would such a mig ever be of benefit to weld aluminium.Just curious really, have no mig that I can tear apart andre-wire to try.Would like to hear what you all think of such a mig,even better if someone has used one, I read they werea thing one time at the low end point.Last edited by Windingroads; 1 Week Ago at 07:27 PM.
Reply:I think it would be useless.
Reply:Your probably right.
Reply:If memory serves, several years ago Harbor Freight sold a crappy little flux-core wire feed that was AC.Reports were that it did suck.
Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Yea,,, that was their "Century 90" I think...Anyway, I had one, worked pretty well for a $75 Flux MIG (better with Lincoln wire). There were people who converted them to DC (I think their are threads in the HF forum right here), I never tried one of those once converted but, I welded a lot of "thin stuff" with it in AC, it worked!
Reply:I try a small AC fluxcore welder 120 volt it did not do the job.It flip the breaker or you had a cold weld. Dave
Originally Posted by Windingroads
Well converting to DC would up the secondary voltage by about 1.4 times, that would help,
GMT+8, 2025-12-18 08:57 , Processed in 0.091053 second(s), 18 queries .
