Lincoln 210mp on generator.
发表于 2022-9-16 15:52:12 | 显示全部楼层 |阅读模式
I'm sure there are other threads on this topic already and feel free to lead me there. But I'm just getting mixed opinions when it comes to running my 210 mp off of a generator. Wondering if anyone could steer me in the right direction so I do not ruin anything. I have a small  4000 watt red d arc gx200.Sent from my SM-A530W using Tapatalk
Reply:I have no idea, but I have seen Jody Collier from Welding tips and tricks use it with a Lincoln Ranger Skip to 5:09Sent from my iPhone using Tapatalk
Reply:I use my 210 MP on my Lincoln Ranger 330 MPX because it has a better than 5% THD (total harmonic distortion).I would not run it on my 7KW Honda powered no-name generator 'cause of concern with the electronics of the 210MP.LINCOLNSquare Wave TIG 200Power MIG 210 MPRanger 330 MPXMILLERThunderbolt AC/DCHYPERTHERMPowermax 190CPowermax 45XPHOUGANHMD 130HMD 505FEIN/SLUGGER 14" COLD METAL CHOP SAW 9" COLD METAL HAND-HELD SAW
Reply:The mp is a heavy duty little welder.  A 4k would be marginal.  But,,,one of the selling points was they were tolerant of power, either it work or won't, if it doesn't don't keep trying.www.urkafarms.com
Reply:I bet the 7k runs it just dandy.  Sometimes I wonder how we ever used a generator without reading everything we can find on the internet?www.urkafarms.com
Reply:Just try welding on generator. Typically a mig/fluxcore can start welding on 3,000 watt generator and stick needs 9,000 watt generator.Dave
Reply:I forget that is a bit of a greedy little bugger and how little 4K is,,, hawww.urkafarms.com
Reply:I run my Lincoln 210 mp on a Honda EU6500i mostly for mig, and often for 1/4" aluminum. Never had any problems. I have also done  gas/gasless flux core on 100ft #12 extension cords with out knocking out breakers. Stick welding seem to pull the most amps on this machine, better off using the Red d arc machine for stick. At 4000 watts it will be limited, mostly to mig and tig anyway. Is that 4000 watt 230V ? You'll be able to run about 120 amps off mig/tig . stick will be around 80-90 amps useable. It really depends on the generator, and the process. No harm in trying, if it doesn't want  to do it , the machine will shut down and restart. Let us know how it goes.RegardsAirco 250 ac/dc Heliwelder Square waveMiller Synchrowave 180 sdMiller Econo Twin HFLincoln 210 MPDayton 225 ac/dcVictor torchesSnap-On YA-212Lotos Cut60DPrimeweld 225 ac/dcPrimeweld mig180Miller AEAD-200
Originally Posted by G-ManBart
Your generator puts out around 16A at 240V.  The manual for your welder calls for 27A....
Originally Posted by tadawson
I just looked at Licoln's rating for this unit . . . I am seeing 14.7A drawn for full rated output on 230V . . . Not seeing the 27A figure anywhere on the 210MP spec sheet . . .???
Originally Posted by Broccoli1
From the manual.
https://www.lincolnelectric.com/en/products/K3963-1The published specs don't match (or there is more than one 210MP) . . .
Reply:27A is the maximum input amps14.7A is the effective amps It will draw 27 A at 200 amps-24 volt output at 25% duty cycle.---Meltedmetal
Reply:HAve used my Hobart 210 MVP on my Champion 3500W / 4375W Dual-Fuel Generator, ran everything out of the bucket on my front loader.  Did fine on a gate repair.  Don’t know how it would do if you needed to run it for a long time.Retired Old GuyHobart 210Lincoln AC/DC 225/125 Evolution 14” Saw
Will it? Or is 27A just inrush? Myself, I'd put an amp clamp on and be certain . . . .
I run my Lincoln 210 mp on a Honda EU6500i mostly for mig, and often for 1/4" aluminum. Never had any problems.Regards
GMT+8, 2025-12-18 12:40 , Processed in 0.089278 second(s), 18 queries .
